4WD Fault Service Required
Safety Harbor, FL, USA
I had the vehicle in park after driving about 15 miles in a parking lot when a "4WD Fault Service Required" notification popped up on my dash. Took a picture, clicked okay, turned the vehicle off and back on again. Drove another 15 miles back home and never noticed anything nor saw the notification again. Has anyone experienced this before?
Yellowknife, NT, Canada
I have seen it get confused when slipping on snowy roads or losing traction around a icy corner. I did the same thing...turned the car off and then on restart all was good again.
mcfarlrm
I'm going to keep an eye on it over the next several days to see if it happens again. I was literally parked for a few minutes when it went off. Just one more potential issue along with a laundry list of other I've experienced.
- Cats replaced
- Flex pipes being replaced (back ordered)
- Intermittent rough idle when AC is on
- Possessed liftgate
- Early crash detection warning with no hazards present
- Rough transmission shifts in sport mode (especially from 1-2 and 2-3)
- Cats replaced
I have all of the above plus clutch, fuel pump, battery, rear camera and rear glass replacement since 2020.
mcfarlrm
Ouch and I thought I had it bad. Too bad I bought used and lemon laws do not apply.
Still love mine warts and all! My repairs were fixed right the first time and wasn't in the shop more than 10 days each time. So lemon law didn't apply.
mcfarlrm
Same here the pros definitely outweigh the cons. I knew what I was potentially getting myself into purchasing a the first year of a model redesign. What did they do to fix your liftgate, transmission and rough idle issue?
Maryland
Had the same issue with our 2020, dealership narrowed it down to one of the speed sensors getting fouled. Believe it was in the front diff. Ended up selling the ST back to the dealership we bought it from and ended up actually taking a profit from it. Had too many issues and was a headache to deal with, placed an order for a 2022 X3MC should be delivered next month.
I got the same fault about a week ago and the vehicle was stuck in 4WD. I checked it with Forscan and got a code stating the "Actuator Stuck". I literally just got off the phone with the service rep who told me it's not covered under the powertrain warranty and neither does my extended warranty cover it! I'm calling Ford to bitch about it. The only reason I bought the ESP was because they said it covered anything electrical.
Have you checked your ESP to see if it states that electrical is covered? Might be worth taking a look.
Yes and the AWD module is one part that’s listed as not covered. It’s probably because so many people have had them fail! Some say it’s the Half-Shaft Speed Sensor that causes it. I’m hoping that once the sensor is fixed (which is covered) it will work properly.
My service advisor said that replacing the half-shaft sensor is the least invasive way to fix this. So far after 3 months and 3,000 miles, it's still fixed.
Well I’ll keep my fingers crossed. You would think that because there’s so many issues with this, they would know what causes it! The guy I spoke with said he’s never seen this issue in the year he’s worked there. I should bring my laptop in and show him some of these threads!
2020 Whitehaven st, Washington DC 20007
Yesterday out of the blue I got ALLLL of the faults, and they’re staying with me. 4wd, advance track, etc etc. Gonna try to replace the battery since I know that’s been somewhat ready to go. But this thread and another one are giving me plenty of anxiety
Desert South West
Have you checked TSB 20-2071?
https://www.tsbsearch.com/Ford/20-2071
Take it to Sheehy Ford. They fixed mine 3 months ago! No hassle under powertrain warranty!
Dang,
Sheehy is a good ways away from me nowadays. I used to live in Arlington not long ago, but now I’m in Tidewater. Keep your fingers crossed for me - picking up a new battery this afternoon
If it’s the half shaft speed sensor…and it likely is…it’s a $20 part and takes about 30 minutes to swap. No way I’d wait on a dealer for weeks and worry about warranty coverage for something like that.
#20
I just got off the phone with the service rep and told him not to touch the vehicle. I’ll pay the $176 diagnostic fee but I’m going to do the speed sensor myself! If it fixes the AWD module issue then I’ll be good. I looked it up and it looks like it’s more trouble pulling the plastic shields off than replacing the sensor.
