4WD or AWD?
I've done a ton of searching and reading on this and I still don't understand. Everything I have on my vehicle (window sticker, specs sheet, owners manual and dash display) all say it's 4WD. The explanation of the system on the Ford site says it's 4WD. But in so many other places it says it's AWD. Based on my knowledge of how the systems work, it appears to be 4WD. I don't see any difference from the older models with automatic 4WD other than it monitors a lot more information. An AWD continuously send torque to both the front and rear wheels. The 98 Explorer I had was AWD and it basically just didn't have an actuator to connect/disconnect the transfer case to the transmission. My moms 07 Freestyle is AWD and it has a CVT (Continuously Variable Transmission) which distributes torque to all four wheel. So, what am I missing here? I think this is just a matter of terminology and not technology.
Clear Lake
2025 Explorer
Good question! I have been wondering about the same thing.
It definitely is technology. Our cars are AWD. Automatic or Intelligent 4wd is AWD. Some marketing person at corporate has caused this confusion. There are different transfer cases that utilize different ways of using AWD. 4wd utilizes a transfer case that forces the car to be in 4wd high, 4wd low, or 2wd all the time. AWD is electronically controlled, with usually no user input, and usually uses a series of clutches to send a certain amount of power (it usually varies) to the front or rear wheels. Most of the time, newer AWD cars will automotically disconnect the front or rear wheels under low-load circumstances for efficiency. Our cars use different actuators and clutches to disconnect or increase the power sent to the front wheels.
