Hey guys! After some research I was able to find a rim and tire setup that I like. I'm hoping that I'm right regarding the specs for my 2020 explorer ST with street pack. Will be downsizing to a 20" and then moving to a 10.5" wide rim. Hoping this setup will get me more flush than stock.
The wheel I'm looking at has the following specs. Rim is Touren TR91. 20x10.5 +35 offset 5x114.3mm 72.6mm with either 285 or 295/50/R20 tires
The website I'm ordering from is stating the wheels will not fit the Explorer ST but I'm assuming that's only due to the hub bore being 72.6mm compared to stock 70.5mm. From my research I would just need to purchase a 70.5mm to 72.6mm hub centric rings.
Unfortunately there's not many photos of 20x10.5 setups on here. Can anyone confirm that as long as I have the hub centric rings I should be able to mount these rims? Also is there any difference between the materials used for the hub centric rings? Aluminum vs polycarbonate...etc
Thanks!!
Thanks!!
- Show All
