So I'm going to bite the bullet and get my 10R60 built when I add the stage 5 turbos next month. I've been going back and forth on whether to get a stage 3 kit from suncoast or have it sent off and built at a shop like Level 10. Either way, I don't know if I need to address the stock torque converter at the same time. These are definitely outside of my wheelhouse. I see that suncoast has one for sale for the 10R60, and Level 10 says they replace the torque converter when they do your build.
The last time I did any real research into the workings of a torque converter was over 20 years ago for the 700R4 in my Firebird. I'm sure things are quite a bit different nowadays lol. So my questions are, is this a part that needs to be addressed when building the trans to handle more power? Is this a potential failure point, or will it be a bottleneck for performance if it's not changed out? If it should be changed, what stall speed should be used? You can choose your stall speed and with how fancy these 10-speeds are now, I wouldn't know where to begin choosing the correct stall for my application. It's 93 octane with all bolt ons and will have turbos as well. I'm assuming 500+ at the wheels. But the torque curve should still be pretty similar to most tuned STs. Any help/advice on this is greatly appreciated!
I wasn't going to build the trans at first, but talking to Adam at ZFG and he said he limits the torque by about 50-70 ftlbs when you are running a stock trans, and I want to get all that extra oomph unlocked since I don't have any ethanol around here so I'm already bringing a knife to a gunfight.
- 1
- Show All
