Best Explorer ST 2022 exhaust just bought today
Safety Harbor, FL, USA
Just got the 2.5" Thermal R&D installed today and talk about a huge difference. The first cold start was amazing and is hardly noticeable at cruising speeds until you step on it.
Miami, FL, USA
2022 Explorer st
Did you get the midpipes as well??
Columbus, MT, USA
I drive approx 50 miles one way every day to work both 2 lane and Freeway. With new 3in R&D I'm in love. There is Absolutely no drone at 65 or 75. A slight drone hint at 85 though especially going up a hill. With my FENG off I can actually hear what it is supposed to sound like and it growls when you want it to. The trade-off for higher speed drone (although very mynute) is worth it imo.
Sacramento, CA
2022 ST
agree with this. 75-85 has a small drone but turn up the radio a bit and its gone
Soccer8888
MN
Do any aftermarket mids have issues with the rattle?
Gary Gordon
Reynoldsburg, OH, USA
The 3 inch is the exact same way you won't even notice it's there until you're on the gas
Sounds nice, I went Borla S and Steeda sway. What did you do to your taillights ? Really like the look.
ARC
Oak Lawn, IL, USA
2022 ST Black
#29
Excellent setup. I have been running mine for the past 10k and no problems.
I just ordered the CV fab downpipes and cant wait to see how it opens it up.
Nfd405
Firefighter
NY
2024 Explorer ST
#30
Borla S here. Completely happy.
Still happy with it? I’m looking for something not too loud at startup as my Ram 1500 with the Borla S was too loud for my condo association.
Bowie, MD, USA
Not too loud at all.
Maryland
I love my Gibson axle back. Easy and sounds amazing. No drone.
You swap out your intercooler yet?
San Francisco
2022 ST
#34
The intercooler isnt bad, but you honestly have to remove the front tires.
I did mine one side at a time with a jack and no help.
I would hawever note that you should have a plan wor the shroud bottom rivets - if you dont have bolts there.
I used stainless steel rivet nuts and Rustoleum to protect the drilled out holes.
Start in the morning and with breaks, you'll be done by dinner.
Consider doing upgraded hot and cold charge pipes while you're in there - there will never be a better time.
ps, The fender bolt orientation was done by an a**hole, they tilt UPWARDS. Use universal joints and patience.
pps, Get some replacement wide zip ties from Home Depot to have a tight reinstall.
#35
The intercooler seems to not be so hard it just seems very time consuming.
San Rafael, CA
I found that the shroud that has either the bolts or the rivets at the bottom is held in place in so many other locations. I drilled the rivets out and didn't go back in with anything. To me, the biggest holder of that shroud is the bolts at the crash bar one both sides.
San Francisco
2022 ST
#37
^ I feel like the bolts/rivets are far enough down, that something should be put back. Honestly the crash bar is over half a foot away, why introduce that much vibration?
