Hi dear community,
I am new to this forum. I have just purchased a new Ford Explorer ST with Street pack, and I am loving it!
Inspired by some enthusiasts in this forum, I ordered from my Ford dealer and recently received a set of 18" police interceptor rims (LB5Z-1015-B) that I am going to use for winter.
Now I have the following question.
Since the original rims are 21", I understand that tires for 18" rims can only be matched by diameter/circumference approximately. The closest sizes Tire Size Calculator suggests are
265/60R18 (-0.7% in diameter), wheel width 7.5-9.5" or
255/65R18 (+1.3% in diameter), wheel width 7-9".
When I talked to the dealer and asked them what tire size the police use on their interceptors, the guy said it was 255/60R18 which is -2.3% from my ST stock size in diameter.
My understanding is using a closer diameter tires would be better than the ones 2.3% smaller. However, I do not fully understand if those LB5Z-1015-B rims would fit 265 mm wide tires properly.
Below are the specs on the interceptor rims (photos). Do I understand it correctly that they are 8" wide, so both 255 and 265 tires would be OK?
Also, in general, which of the sizes above would you recommend me to go with based on your experience and common sense?
Thank you!
Thank you!
