BeyondEOD's 2022 ST Build Thread
BeyondEOD
Active Duty U.S. Air Force
Missouri
Purchased this ST with just under 30k miles in November 2024.
*awaiting install/ordered
Engine:
  • Steeda Intercooler*
  • NGK 95605 spark plugs gapped at .28
Tuning:
  • Cobb Access Port Tuner with @GooseTuned 91 octane tune
Suspension:
  • Steeda Subframe Bushing Support Kit*
  • Steeda Vertical Link Billet Reinforcement Kit
  • FenFab Toe Links*
Driveline:
  • Steeda Rear Diff/Pinion Bushing Kit*
  • Steeda Extreme Differential Bolt Kit
  • JXB Driveshaft Center Support Bearing Carrier - Street*
  • JXB Differential Bushing Insert
  • FENFABracation Transmission Mount Insert*
  • AWR Racing Rear Diff Mount Brace*
Exterior:
  • Ford Front Mud Guards
  • OCD Plug Gloss Black PPF - Pillar Kit*
Interior:
  • OCD Plug Infotainment Matte Screen Protector*
  • 35% Transparency Ceramic Window Tint - All windows except windshield
FORScan:
  • Bambi Fog Light Mode
  • Disabled fake engine noise
  • Powerpoint time out set to 360s
  • Parking lamps enabled with DRL
New Mexico
:cool::cool:
B
BeyondEOD
Missouri
Just got the JXB single diff bushing support installed last night along with a Steeda 12.9 bolt. The Bushing insert slid right in with the supplied grease. Also installed the Steeda vertical link inserts.
B
BeyondEOD
Missouri
Replaced the spark plugs last night. Not too bad of a job. All went well. Gave it one boost launch and the wheel hop was pretty rough. FenFab Toe Links are on the way now.
The Toe links, Vertical Links, and subframe links will eliminate most of the wheel hop.
B
BeyondEOD
Missouri
I hope so, I’m still rocking the Cobb Stage 1 tune and she is hopping. Steeda Vertical Links are in. I’ll be working on the subframe inserts tonight. Maybe the Steeda front bushings for the diff if I have time.
B
BeyondEOD
Missouri
Any input on getting a Granger Ford Extended warranty with what I’m doing? If I did the Basic for 75k/6yr that would cover me till 2028 for right over $1k.
