Blow Off Valve for the ST
Lecanto, FL, USA
I have not had any issues with mine.
Bennsville, MD, USA
Anyone get a Check Engine light with the install of the Turbosmart BOV? Had mine on for 3 weeks or so. All good and just threw a code tonight. I am going out to see which one. FordConnect App says it has to do with electrical and the turbo.
nothing since I installed it this past may.
ChrisnlBC
OC
Thanks Fellas. Wonder If I got a bad valve heres the code. I reset it and lets see if it returns.
ChrisnlBC
OC
#27
this may be a stupid question but where did you get the software/hardware to read codes and reset?
Not stupid at all. I have a cheap Wifi Ecu scanner from amazon and OBD fusion iphone app.
Reset and it hasnt returned yet. This is after a long trip also. No issues knock on wood.
Jwbreeding
Active Duty U.S. Air Force
Charleston, SC, USA
#29
I like the sound of the bomb one. I had one for my fusion, I still need to hear the turbosmart version.
Sanscritt
Kentucky
#32
How difficult is the install?
Jacksonville, FL, USA
#33
id go for the Whoosh motorsports BOV adapter. Same as boomba for almost half the price. Sounds great / identical to boomba
KegsBdry
WashDC
#34
Boomba is a good, well known brand. I've had a turbo blow up due to an aftermarket BOV before on an ST. Costs were well over $2K to fix. I'd stick to good parts that you can trust.
I'm new to the Whoosh products.
#35
So supposedly the Whoosh BOV is identical to the Boomba but I'm intrigued to hear what BOV you had on your ST that was responsible for exploding ur turbo. I'm guessing it was probably a home-made concoction of misc universal parts?
Neither of the things you list are BOV’s. They’re simple VTA spacers.
Las Vegas, NV, USA
#37
surprising you had an "ST" and never heard of us, we manufacture intakes, intercoolers, big brake kits, charge pipes, oil drain plugs, BOV spacers, short shift kit, CNC bushing kits, shift knobs, engine mounts, gel and vinyl decals, symposer deletes, hybrid turbos, downpipes both catted and catless, etc etc etc under our house brand whoosh motorsports
along with the hundreds of parts we retail for other manufacturers
We also have the largest selection of Explorer ST parts of any other site you'll find. Give us a try!
www.whooshmotorsports.com
Sanscritt
Kentucky
#39
Do the VTA cause any problems? I know they don’t do anything to help, just the noise, but do they cause and possible problems?
KegsBdry
WashDC
#40
Looks like I have some learning to do. Thank you.
