Blown Transmission
Charlotte
2024 Explorer ST
#81
He told me they got the transmission out and found that a vent tube was melted from the cat of the aftermarket exhaust. He said this may have caused the transmission to overheat and fail!
So they are blaming the down-pipes causing heat melting a tube? Crap , just had downpipes installed, maybe I should have had them wrapped. Did you take any preventative measures after your ordeal?
Thread Starter #82
They just made sure the tube was clear of the exhaust when they reinstalled everything.
powerboatr
I just re read this entire thread
You didn't have tune installed at time of trans taking a powder?
Good it turned out positive
Maybe ford needs a metal vent tube
Even stock...space is freaking tight
Thread Starter #84
No, It wasn’t tuned. It was going in for warranty work so I never put it back in.
powerboatr
Did you ever get any post mortem on what failed?
