Blowoff Valve
DC Area
I know the blow off valve questions are getting wild
As a novice I just want the best one without the headache
How would you rate :
GFB VTA Blow Off Valve
VS
TurboSmart Blow off Valve
Thanks
If you’re just looking for easy sound, the VTA mod is the best. Better then spending money on a new BOV.
His info says 2020 so he probably has the bypass valve like I had.
Lewski
DC Area
I'm sorry ..I was not speak of the mod but the whole GFB VTA Blow Off Valve
I have a 2020 and did the VTA mod. I don’t recommend it. They say it doesn’t cause loss of power but it felt sluggish to me so i hooked it back up. Got annoying anyways tbh.
I understand that but for only a couple dollars you can save money and have the same sound.
Lewski
DC Area
Thank You
So it's about the sound or not ?
I'm guessing they all doing the job the factory pieces is doing .
Cool
Lewski
DC Area
Thread Starter #12
Okay ... Thanks for results
It will help with understanding
Thank You
Cool
Yes, BOVs add zero power. The VTA mod is perfectly safe and doesn’t hurt power at all. There are a lot of variables that could’ve have contributed to a sluggish feel.
I have a 2020 and had the OEM bypass valve. When I installed the Fenfab charge pipes, I had to go to a BOV. I didn't want the sound but TBH, you can't really hear it unless you have the windows down, the radio off and you let off the throttle real quick. Otherwise you never hear it.
