Brake caliper upgrades?
Melbourne, FL, USA
Any specifics on the difference between the basic ST and the red calipers? Are they actually bigger in some way? Rotors the same diameter and width?
Has anyone found a monoblock caliper that would fit? Seems like most of the 2020s left are base brakes and 20" wheels (which frankly I prefer), but I would feel like I'm missing out brakes wise if the red calipers are bigger with bigger rotors...
BlkGS
Melbourne, FL, USA
Hmm, yup that's what I was worried about, lol. I suppose a rotor upgrade isn't that hard, but that'd also require a calipers.
Probably not worth it.
BlkGS
Melbourne, FL, USA
Anyone happen to know the bolt to mount spacing for the caliper mounts?
DoingOK
Smithfield, Virginia, USA
I actually have someone in line to do some measurements for me to adapt either 6-piston Brembos from the GT or CTS-V calipers. Going to work on this after the holidays. I'd love it if I could get the carbon ceramics from my vette on the ST......but the cost is ridiculous.
SoCal CA
Mounting spread is 140mm.
Corvette C6/C7 CCM rear calipers have smaller pistons so they are not suitable for Explorer front.
Aftermarket brake upgrade/replacement like those available for Jeep SRT8 is probably a better alternative than OE's performance brake upgrade.
SoCal CA
Yes, in fact we have an offer using Jeep SRT8 WK2 (2012+) 6 pot calipers (w/380x34mm rotors) for a 100% bolt on installation to Explorer's spindle - without modification (No spacers, no adaptors, no trim & cut) - All design criteria and OE parts are in our possession so no try and error.
WK2 front 6 pot caliper:
Another alternative option is to consider RB 6 pot caliper (380x34mm rotors) kit (including rotors, pads, calipers, adaptors, and hardware.) which as you can see from the pic, our 6 pot constructin is more refined.
Lakeland, FL, USA
Any idea when this will be avaliable? Website shows a pre-order status. This would be my first DIY project and I would be interested in buying this kit for my ST.
Edit; in question is the 6-pot from the SRT Jeep to the Explorer ST
Sent from my SM-G975U using Tapatalk
SoCal CA
The rotor kit is being made but since they are not available yet so we can only accept pre-orders so customer would know there is a leadtime.
Yes, the rotor kit includes rotor and pad (optional) and customer has to acquire a pair of Jeep WK2 SRT8 calipers (6 pot) as shown in the pic from Dodge dealer or eBay.
Lakeland, FL, USA
Okay, so I would have to source the calipers for this kit?
Would they go to you or...?
SoCal CA
No regret for base model owners. You keep $1600 upgrade charge in your pocket and purchase only the rear RED calipers (from Ford dealer or eBay*), after that you are 100% free to upgrade your Base ST to Sports brake and beyond.
Picture below illustrating a longer bracket is being made available for rear BBK, but stock size bracket can also be made available for base model.
*If you order from Ford dealers caliper and bracket are two separate parts but if on eBay they often come together.
Please follow this thread for the complete coverage on available upgrade development.
https://www.explorerst.org/threads/racing-brake-is-in-the-game.1448/
SoCal CA
You can purchase them from Jeep/Dodge dealers (68146610/11AA (Right/Left)-$734.40+$55 for core/ea) Or Search eBay for used calipers for about 1/2 of the price ($380)::
The brake pad pin and spring kit are extra from dealer, but may be included in used units.
About $800 each according to their ad.
If you ever need to rebuild the calipers we offer replacement components and rebuilding service.
https://racingbrake.com/search-results-page?q=bj-61
We don't just know how to make the parts right, with our in-depth knowledge and resouces we can assure Explorer owners that you can seamlessly (and progressivly) upgrade your Explorer (Base or Sports models) to SRT8/Trackhawk and beyond as your needs and budget allowed.
SoCal CA
The SRT8 WK2 caliper kit (w/380mm rotor) was up on the test bench and everything fit as expected. (Note this hat was used for simulated test only)
Please click the item line for more information.
Weight comparison (between ST sports brake and WK2 retrofit kit)
Amarillo, TX, USA
21 Explorer st
I would and did. Too many ppl complaining about the calipers either completely falling apart and peeling on the optional street pack brakes. Save your money and get brakes and wheels you really want. That's the only difference. Not too mention the "regular " brakes on the ST are actually perfectly fine for street use.
