Good news for those with 2025+ Explorers (will be all trims). Those who are wanting to enable cameras at speed and are encountering the issue with the annoying black box in the middle of the screen that says "Full Screen Not Available", the changes below allows you to enable your cams while you're in drive and at any speed! All you have to do is press your camera button in the buttons row, right next to your volume knob and it'll work!
APIM -> 7D0-02-02 -> xxx*-xxxx-xx--
(If your current value is 0 then change to 1, 2 change to 3, 4 change to 5, 6 change to 7) NOTE: Reboot APIM after the change.
**Always remember to make a backup of your APIM module before making any changes, just in case and to be safe.
--Cheers!
--Cheers!
