Take the whole console out, it's not difficult. A few bolts and trim clips. Instructions are out there and in the service manual, which I suggest investing in. You can access the door/cover from underneath the console to remove. I broke it taking it out but it wasn't necessary to remove. I just have no patience and I knew I wouldn't be needing it any further. For my install I mounted a Cencom core control head in the pocket. Power is right there for the accessory plugs. You can use forscan to modify the time out time on them to keep them powered after ignition is turned off.
