Hello I am getting the charge system light and it’s intermittent. I have done basic diagnostic checked fuses checked wiring checked the BMS everything looks good. I’ve tried to use the explorer 3.5 charging circuit wiring diagram to see if I may have a loose pin somewhere but it’s totally different then the st. Does anyone have any suggestions on where to look or if someone can upload the wiring diagram for the charging circuit with the right PIN numbers and wire colors I can do a little more diagnosing. Thank you in advancd
