Cold Start Blue (burning oil smell) Exhaust
Yort3000
Edmonton
I have started to notice upon a cold start that there is a moderate volume of blue exhaust that comes out. It smells like some oil is being burnt somewhere. This initial exhaust is only temporary.
I have seen older posts with the same issue but did not see if Ford resolved it or what the most common culprit of this is. Does anybody know what the issue is and how to go about getting it repaired?
I want to go into the dealer armed with some knowledge so they can’t just dismiss me and say “iT’s nOrmAL”
It's possible that it's only a bit of residual oil/moisture in the exhaust. However, if it happens very quickly after starting and then dissipates, you have to look at the heat source, and the fastest heat source is the turbine. That would tend to point one in the direction of the turbine bearing seal which has been identified as a problem in the past.
If you have a lot of miles, or have a spotty record in changing the oil, the other culprit could be a valve guide.
Y
Yort3000
Edmonton
It’s a ‘22 with only 17,000 km or 10,500 miles. I also change the oil every 5000km (3000miles). I’ve been checking the oil often and it stays fairly consistent.
michigan
I too have noticing the same thing. I have a 2022 with 15k miles. Only happens on a cold start. Smoke come out about 5sec after start up and last about 3 secs
