Coming soon aFe sway bars
Detroit, MI, USA
#41
C
US
Thread Starter #42
Why is there blue paint on the springs?
I am not sure.if they had marked it for some reason or if it had been marked by ford. It is not from the sway bar though, if you look in the second pic you can see there is a ton of room between the bar and the spring.
C
US
Thread Starter #43
Hey guys. Just a follow up on aFe's sway bars. Their link is up and I will include it here with the details on the sway bars.
CNC Bent, Tubular Front & Solid Rear Sway Bars
Ø38mm (1.5”) Front Sway Bar, 3-Way Adjustment
387 lbs/in (31% Stiffer than Stock)
425 lbs/in (44% Stiffer than Stock)
475 lbs/in (61% Stiffer than Stock)
Ø25.4mm (1”) Rear Sway Bar, 3-Way Adjustment
227 lbs/in (97% Stiffer than Stock)
260 lbs/in (126% Stiffer than Stock)
290 lbs/in (152% Stiffer than Stock)
6061-T6 Billet Aluminum Bushing Brackets
90A Durometer Polyurethane Bushings
Durable Red Powder Coat
Direct Fit Installation Requires No Modifications
Proudly Made in the USA
https://afepower.com/afe-power-440-304001-r-afe-control-front-sway-bar-set
I hope this helps you guys with some of your upgrade decisions.
