“Creaky” steering.
BorrowedTime
Jax, FL
Hello everyone,
So…we have some “creaky” steering going on with our 2020 ST (32k miles). It is noticeable at a stop or while moving at slow speeds. I’m sure it’s there at higher speeds but we can’t hear it due to wind noise, etc. I had my wife turn the wheel back and forth while in the garage with the hood open and engine running, and I’m almost certain the steering box/knuckle appears loose while hearing the noise. It might be something loose on the power steering rack as well. Not 100% sure at this point but it is noticeable enough to be embarrassing at slow speeds in parking lots and so forth.
Has anyone else had a similar experience? If so, what was your issue and subsequent solution?
Thank you in advance.
Regards,
Joel
Hello everyone,
Regards,
Joel
I have heard of this problem happening to anyone before. Are you still under warranty?
B
BorrowedTime
Jax, FL
Unfortunately, no longer under warranty. So, this is a known issue to occur in rare instances?
No, I’ve never ever seen this issue from my all the time I’ve been around the forum and all the groups.
B
BorrowedTime
Jax, FL
Well, at least that’s a good thing on one hand. I’ll report back once I figure this out.
