Cruise control has a mind of it's own
Mize442
Salem, OR, USA
Has anyone else experienced the following. The following happens alot.
Cruise is set at 60mph then all of a sudden it jumps to 70 and sometimes even 80mph. I haven't touched any control or buttons, brake or gas pedal.
It will even go from 74mph to 60 on its own.
Thanks for any help
CoastieN70
U.S. Coast Guard Veteran
Travelers Rest, SC, USA
Adaptive cruise control set high but on a heavily traveled road?
I discovered that if you hold the set button on the "+" side the cruise control will rapidly run the numbers up on your "set." You may be experiencing this without realizing it.
M
Mize442
Salem, OR, USA
Thank you for your reply. I have experienced what you mentioned, but this will happen without even touching anything on that side of the steering wheel.
Burke, VA, USA
There is also Intelligent Cruise Control. You can set your cruise speed a certain mph over/under the posted speed limit, and the car automatically adjusts. i.e... You set your desired limit at +15 mph. If the road you are on's speed limit is 55, your car will automatically go to 70. If the speed limit is 30, you will go 45.
Tammyjr
Williamstown NJ
2020 ford explorer
Help my car pick up speed when in cruise control. I was told by a attorney for ford no one else is having this problem. Please email me now navigation screen is not working and radio goes static. Mind of its own.
AkD3ntFix
Akron
If you give it a little gas while in adaptive. And happen to close the gab with the vehicle in front. The adaptive distance will break fairly hard to shave speed to maintain the distance that is set.
if your have cruse set at 80. Come up behind someone doing 70. You’ll slow down and keep assured distance that’s set in the adaptive. Holding that spacing till they move over. Once the lane is clear. You willl accelerate back up go 80. Till the next slow obstruction.
Sarasota
Lets be honest here, they don't move over. :)
