CvFab Intercooler / FenFab HKS Charge Pipe Kit Installed
Bran1093
Moorestown, NJ
Hey Folks!
Received my pipe kit from CvFab on Friday so i was able to get these installed yesterday.
Hardest part of the install was the darn C clamp setting the Bov to the flange (snap ring pliers for the win)!
Polizi212
Looks like a fun time! I am waiting for the weather to break and stay warm before I tackle the Intercooler install!
Hey Folks!
Nice work! Looks good!
DaGooch
Illinois
Hey Folks!
Looks good. I am trying to find time this weekend to do mine. Question... did you replace the rivets that need to be drilled out with anything or did you leave it alone? How about the zip ties that need to be cut?
B
Bran1093
Moorestown, NJ
Yes, I drilled out the rivets and replaced them with the Zip ties that come with the IC. The ZIP ties are hefty size so I did have to take a bigger drill bit to make the hole a bit bigger in order for the Zip tie to go through.
Lincoln Aviator
Did you have any issues with the hotside charge pipe installation? Specifically, how did you remove the non-screw type clamp that secures the coupler to the passenger side turbo?
I'm in the midst of an install currently.
If your talking about the crimp style, you have to cut it. I replaced all my connections with T-Bolt clamps.
