Disabling hyper flash with forscan
Golec
South Bend, IN, USA
Alright so I dabbled with forscan last night for the first time and changed a few things so I have a slight bit of knowledge of the system. I was wondering if anyone could help me out with how to disable hyper flash as I will be replacing the rear turn and backup bulbs to LED today, and they do not have a resistor..
I did a quick google search and found a bunch of info on f150’s and other ford models but I couldn’t get a definitive answer for a 2021 ST…any help would be greatly appreciated
JohnE
Vancouver, WA, USA
If I remember right, it says something like “Left Turn Signal Out”, “Right Turn Signal Out” and you’ll disable.
Golec
Golec
South Bend, IN, USA
alright, thank you. I saw that but I wasn’t sure. All the other stuff I saw online, you had to change a 1 to a 0 in a completely different screen that was labeled as “as built”
JohnE
Vancouver, WA, USA
Yep, it’s much easier to go with the simple enable/disable screen, which I think is the “As Built” screen.
