Doing the PMI on the AWD module
kuilima
Active Duty U.S. Air Force
Kekaha Hawaii
2023 Ford Explorer
Hello,
I’m not sure if this is the correct place to ask this question, sorry if it’s not.
I have a 2023 Explorer that got wet inside and I needed to replace the AWD module under the drivers seat. Now I need to do the PMI calibration as required by the service manual. It says basically take it to the dealership to have this done. My question is, can I do this required update/calibration using FORScan?
Thank you for any help !
I've never done it, but my understanding is that if you load factory As-Built data for the AWD module in Forscan, and then write it to your new module, that should work.
