Door Key Code
Evansville, IN, USA
Is there anyway to get the door key code without going to a dealer? The used ST I purchased didnt have the factory code and if they did I dont know if was changed even if it did. FORScan cant grab it or anything?
Check the folder that your owner's manual came in. It's supposed to have a card with the original code. Otherwise the dealer can do it for a charge, I'm afraid.
Calgary, AB, Canada
There's a procedure you can do yourself to get the master door code, I don't remember exactly how to do it, the service advisor did it pretty quickly.
Get both sets of keys, put one in the key fob holder in the centre console, hold down start button for full accessory mode, turn off.
Get the 2nd key fob and repeat the process
The master door code should pop up on the display.
That may not be the exact process, but you should be able to find a YouTube vid on it.
Calgary, AB, Canada
The key fob holder is in the centre console under the armrest, behind the wireless charging pad.
DoingOK
Smithfield, Virginia, USA
^^yup.....had to do that for mine.
T
Evansville, IN, USA
That worked like a charm! Thank you!
