I own a 2024 Explorer ST; after driving for about 15 min, when the brake pedal is pressed, there are warning messages that pop up and flash on the dash. Rear hatch open, third-row occupancy sensor failure, and no key detected. Along with this, the driver tail lamp flashes when the brake pedal is pressed, the vehicle will not unlock with the fob, the sun roof will not operate, and the folding mirrors will not fold. If you lock the vehicle all the lights flicker and flash in random patterns. I have to manually unlock it, it sets the alarm and I have to start it to avoid the alarm going off. I took it in and they replaced the rear hatch latch and cleared the codes. The next morning, after driving for about 15 min, it started again. This time I went on into work (I am the COO of an automotive repair shop) I pulled the codes, but this time, I noticed that after it cooled down, the codes went to history. (All communication failures and open circuit failures). To summarize, after operating temp is when the failure occurs, but only when pressing the brake pedal. This leads me to believe that there is a communication issue with a module that is somewhere in the rear of the vehicle or that operates the rear portion of the vehicle. I know this may be a long shot, but has anyone seen this?
