Has anyone replaced the LED stop lights yet? II wanted to replace them with flashing stop LED lights that flash 3 times quickly then stay steady. It definitely gets the attention of anyone behind you. You've probably seem them around.
I see that two of the lights in the tail light assembly are twist off bulbs (replaced them with LED of course) but the LED light is just a straight clip/push in. There looks like there is a clip on one side that can be pushed in or pulled out to release the bulb. Just checking to see if anyone has done this before I try it. Don't want to break anything of course.
