Fluids Change - Need clarification
Gurnee, IL
Hey Folks,
I have searched for the last hour on this and keep getting conflicting information.
Trans fluid - Some threads say you need 10 quarts, some 12, etc. Let's say my fluid has never been changed at 52K miles, how many quarts do I need to buy to drain and refill?
Front/Rear diff - I am seeing 2-3 quarts for the front diff, and 4-5 quarts for the rear diff of two different fluids. Can someone clarify how many for the front and rear?
I am buying all Amsoil, and right now for fluids based on the conflicting info, I am going to spend well over $300 on fluids.
Want to be sure of what I need so I don't overspend.
Thank you!
-Chris
FORZDA3
Gloucester, VA, USA
Front diff capaity is 0.6 qt so just buy a quart (it's expensive).
Transfer case: Buy 2 qts.
Rear differential: Buy 2 qts.
Trans: you may only spill 6 qts but Mercon ULV is not commonly found so I would have extra on hand. There are also synthetic aftermarket ULV oils available. Not sure what Amsoil equivalents are out there or if they are any that are OE spec.
Here's the oil/capacity list:
Automatic Transmission: Motorcraft® MERCON® ULV Automatic Transmission Fluid 12.6 Qt
Transfer Case: Motorcraft® MERCON® LV Automatic Transmission -AMERCON® LV 1.1Qt
Front differential: Motorcraft® SAE 75W-140 Synthetic Rear Axle Lubricant 0.6qt
Rear differential: Motorcraft® SAE 75W-85 Premium Synthetic Hypoid Gear Lubricant 1.9qt
G
Gurnee, IL
Thanks for the info.
Does this look right?
Trans/Transfer case: Amsoil synthetic automatic trans fluid - 12/QT (Case price)
Front diff: 75/90 Severe Gear - 2 quarts
Rear diff: 75./140 severe gear - 2 quarts
G
Gurnee, IL
Motorcraft® MERCON® LV Automatic Transmission Fluid XT-10-QLVC - 2 Quarts
Motorcraft® MERCON® ULV Automatic Transmission Fluid XT-12-QULV - 12 Quarts
Motorcraft® SAE 75W-140 Synthetic Rear Axle Lubricant XY-75W140-QL - 2 Quarts
Motorcraft® SAE 75W-85 Premium Synthetic Hypoid Gear Lubricant XY-75W85-QL -1 Quart
Going with OEM to simplify things, provided the cost is similar to Amsoil.
G
Gurnee, IL
Motorcraft fluids are about $260 on Amazon.
That includes the one I missed, which is the XL-12 transfer case fluid.
Thanks again for the help.
Check with RockAuto first
You need 2 qts of the 75W85 and only one qt of the 75W140.
Mercon ULV is not synthetic. Triax ULV or Valvoline ULV (both synthetic) are what I've been going with lately.
Must use something that meets spec. I used motorcraft ULV first change then switched to LiquiMoly Top Tec 1850. Fully synthetic and officially meets spec. Always liked Valvoline too but got a deal.
G
Gurnee, IL
Thanks for your help.
Bought all motorocraft from a local dealer. Came out to $220 for everything.
Jessup, MD, USA
Have you noticed any improvements since switching to LiquiMoly?
South Carolina
How was Valvoline? It’s so cheap compared to motocraft. $9 compared to $31 for a quart (rear diff)
I would not hesitate to use their full synthetic gear oil. I ran it in my trucks at my business for 30 years.
South Carolina
Will 75W-90 be ok to use instead of the 75W-85? I don’t have enough gear head knowledge to know the pros/cons lol
Should be fine. I used Redline 75w90 synthetic for the rear diff just because that's what i already had.
Yeah what he said, no problem
South Carolina
Similar question for the front differential. Will 85w-140 be ok to use? :LOL:
Not really. Shifted pretty good with the tune and I change it more frequently than most. I think it’s more about fresh fluid than which fluid a song as synthetic and meets spec.
