Focal, Mosconi, Illusion and Helix build
Very nice. I own a tool company and I still don't have enough cool tools :(
Thread Starter #102
Gutted the whole back end and started running some wiring…not exactly what I had planned for it but it’s out of the way and works. The small distro blocks are to pull power for the DSP and lighting. 2958AB95-D1DA-4EB8-AEFB-49EC0B6C412D.jpeg
Thread Starter #103
Enclosure with top panel built and everything mocked up in place. I don’t love it but I only have so much real estate to work with. Trim panels, wiring and upholstery tomorrow. FEA1A910-1447-4214-9426-DD747C979568.jpeg
Thread Starter #105
Thread Starter #106
All I wanted today was to get it in and functioning. I’ll have to build something for cable management later. I have some ideas just ran out of time. Gotta pull it out again anyway…I guess when I dropped one of the subs in the speaker wire is close to the cone…that makes a nice noise. lol 534FAC30-611B-494E-90A4-1874CB5053FA.jpeg
I like this look better than the other one.
Yorba Linda CA
It sucks that the brand name wouldn't allow a clean install unless the name was upside down. Either way, I would know it was upside down and it would bug me not seeing it, and would bother me with the cables up front. I look forward to seeing what you do with them, looks great though with some great components
Thread Starter #109
I had new emblems made for the Pro’s when I had them flipped backwards…that was easy. The Zero 3 has it carved in though…not so easy. I have some connections at Orca Design…gonna see if I can get my hands on a trashed case from a AS, Zero or One amp and cut the emblem out to make my own badge. Maybe polish it or something. I’ll still built something for cable management in the next week or so when I find some time.
Thread Starter #110
Drawing up an amp mounting plate today to be cut out of 1/8” aluminum then the amps will be on 1/2” spacers so the wires can turn and run straight in under them. That should clean it up nice. I’ll sleeve all the wires and I think it’ll be presentable.
IL
I was just going to ask how you are planning on mounting them. I remember seeing metal of some type on the last build, I want to do something similar but they need to be super secure. You could have a CF emblem made for the amp as long as that part of the heat sink doesn't get hot.
Thread Starter #112
Had to wait on a tiny M3 x 0.5 tap but slow progress is still progress. And damn I hate drilling acrylic. D81A6297-8008-4D75-AC9A-DB4BF76C0683.jpeg BCED72E2-CA7E-44BC-8CB6-D8DFE7D5DE69.jpeg
Thread Starter #113
3/16” aluminum plate for the amps courtesy of a buddy with a waterjet. 3B4579CB-40B0-459F-B814-8BEB61F2343B.jpeg
Thread Starter #114
My techflex and shrink wrap didn’t make it this week but I still wanted to see it closer to complete. I think it’ll work just fine once all the wires are sleeved black.
Thread Starter #115
Did some hacking and got the mounting cups epoxied into place. Next weekend will be fiberglass, bondo and lots of sanding….maybe some paint. They’re aimed at opposite headrests…the look weird in the pics.
A28E8473-C560-4A74-BBD6-FB2F18BB4906.jpeg E1F618F8-DDE7-41DC-8CF0-E5F9D84A42B4.jpeg E37C616C-1D7E-4A51-8F61-CB9FED06BE99.jpeg 3405BE8A-6542-4F68-B3BA-5D7AD28EDE4E.jpeg 979866F7-0D4F-477F-AEA8-36A744B6A2FF.jpeg E6554043-9BC9-44DE-B448-7EA35DDD6500.jpeg
Thread Starter #116
Cloth stretched and coated in resin. No going back now. Fiberglass tomorrow night then sore arms on Saturday….lots of sanding to do.
8BBDC755-9D5E-4F82-937C-194BEC6BACC2.jpeg 5C020A54-91FE-46B6-AAFB-387CEB9006BE.jpeg 1E6603E6-F605-4EA5-8944-F2367783E71D.jpeg
Nbk4t5e
San Antonio, TX, USA
Agreed! I just don't have the patience for that level of detail. Impressive to watch for sure.
Is the impregnated cloth secured by tiny rivets? Or are those some other type of fastener? I've seen some fiberglass work before, but nothing like that! I would have expected hand shaped foam so that's not a technique I've seen before. In any case, impressive work and very labor intensive!
Thread Starter #120
This is the way it’s done with audio builds. Resin doesn’t bite to plastic very well so you drill tons of small holes for it to pass through to make a mechanical connection. The cloth is put in place first with hot glue so you can move it if needed then after it’s trimmed you hit the edges with CA glue then resin over everything and into the holes. I’ll add a few layers of chop mat and resin tomorrow then knock down any high spots on Saturday and start with body filler.
