Ford Performance Tune
schmove
Earth
From the files themselves :)
I work for HPTuners. I picked up an Explorer ST recently and was browsing the forum when I came upon this thread, so I thought I'd inject some of what I know.
Nice to see Bugasu here, I read a lot of threads in the Focus RS forums that he participated in.
Bugasu
ND
Very cool! Any other good info? 93 octane truly a requirement? Towing really not ideal? No idea if you could know that from what you do and can see but worth an ask as it’s been addressed here before.
Either way, whatever ford did or didn’t do, the tune has made a very noticeable difference in the way my ST performs. Nothing ground breaking but clearly improved.
So they initialize the Knock Octane Modifier (the primary control over the octane detection) to 1.0 (max spark advance), and they use a more aggressive spark setup than stock.
I think you have enough room to drop to 91, but dropping lower will really drop the performance. It will aggressively pull spark, but I dont think it'll pull back as far as stock can (which enables stock to run on 87). I wouldn't put a lower octane in unless its your only choice in an emergency, and if so, stay out of boost.
As for towing, I think their reasoning is just the higher loads seen in extreme situations (Think a Super Ike Gauntlet from the Fast Lane Trucks). Cooling is usually your enemy towing, and the Explorer ST already has a dismal intercooler (designed for fitting the Police upgrades is my guess).Its likely they recommend against it because added power is added heat and in an extreme towing scenario, I could see issues. If you're towing 2000lbs across the Great Plains though, probably not going to pop up as an issue. They left most of the stock towing functionality and trans tuning in place, so I dont think you'd have any issues with something easy, but if you're towing near capacity and using the new found power to tow, the cooling system probably wont keep up with you.
st8
Bel Air, MD, USA
Awesome info, thanks! I mentioned the octane piece cause I had a FP representative tell me dropping down below premium can put a hole in the piston. I have no idea. I’ve gotten use to the premium prices at this point. The performance is worth it.
GOODGUY100
Loveland, Co
23 Explorer ST
Any word on when the M-9603-EX30 tue will be available on the 2023 My dealer tried to install it and it would not install on the 23 model
st8
Bel Air, MD, USA
Have you reached out to the FP team? They should know.
Charlotte
2021 Ford Explorer ST
Just got the tune install by the Ford Dealership. Cost was $90 but I pre loaded the tune file on the tuner.
Outside Temp is 50F
Intake Temp is 69 F (Nice)
ST (Normal Mode) is making 18 PSI Boost at 3/4 throttle. (Stock is about 14 to 16PSI).
Taking it easy. Waiting on the tranny to relearn.
Does the trans go through a relearn when the FP tune is installed? Or is that something you had done separately? I had to have a trans relearn done on my stock ST, curious if it undergoes it again once I get the FP tune.
Read post 662
The Dealer said take it easy for the first 2 days.
Maryland
My new best on FP tune.
If you want it to relearn you driving like a grandpa then sure. If you want it to relearn with some pep in it’s step…then drive it like you plan to drive it.
My Livernois instructions says the same:
"several miles and/or days of driving may be required for all adaptive learning to complete. Do not be alarmed at shift quality immediately after installing of tune. It is recommended to do light throttle driving until shift quality has stabilized"
FORZDA3
Gloucester, VA, USA
Those instructions really aren’t applicable to help the vehicle in any way. They’re an attempt to prevent the ignorant public from complaining about shit immediately.
You know, that expectation of instant gratification.
Pleasant Valley, MO, USA
So for those who may have followed instructions for the first time in their lives, would the fix be to reset the transmission tables and drive the vehicle like you should have in the first place?
Calgary, AB, Canada
Basically yes.
They help in that if you reset it and are banging gears driving aggressively, then hopefully you have enough sense to take it easy.
Perhaps @Bugasu could chime in here on the trans parameter tables that are available. I will admit, I haven't seen a comprehensive list of the programming parameters are available on the ST transmission. Certainly, there are parameters related to engagement timing related to clutch tolerance. There are undoubtedly parameters related to line pressure and engagement timing relative to torque. However, this discussion has moved onto "trans learning", with some claiming you should drive it carefully and others advocating for "drive it like you stole it as it will learn your habits".
I may be wrong, but I think it's highly suspect that it has to do with "learning" your driving habits.
If I'm correct in that assumption and the trans parameters have been "reset", it's probably not a bad idea to take a bit of time to drive more cautiously so the tolerances I listed in the third sentence of this post can be integrated into the algorithm. Given that the ST offers different drive modes, unless someone shows me tables related to some type of algorithmic behavior to "learn" driving habits, I'd take it easy at first.
For those of you with a software background (and even those who are reasonable, logical thinkers), what driving "habits" should the software take note of in order to modify the gear/clutch engagement. Does it know when to not incorporate your habits when the engine's cold and you're not stressing it? When exactly does it decide to "fix" your driving habits into software parameters? I think some of this is simply advertising of certain manufacturers claiming adaptation to your habits, but what are those habits, truly? Certainly, I would think it might have something like simple drive mode switch- say eco, agressive, and perhaps race, but I would imagine those are taken care of with the drive modes. This can be easily seen in things like the torque converter engagement in the various modes as well as the speed of upshifts and skip shifts.
New York
2022 Ford Explorer, ST
I would think this is a no-brainer!
Bugasu
ND
Sorry on the late reply.
The primary values tuned in a 10 speed are actually essentially desired times for certain actions that happen, the torque rates involved in transferring torque, and when to shift.
As for what's adapted, each clutch has basically 5 states it can be in:
- Off -
The clutch is spinning freely with no torque transfer and no fluid in the clutch actuators.
- Fill -
This stage the clutch actuators are essentially filled with fluid and all the lash is taken out right up to the point of before the clutch bites. Being underfilled or overfilled here means either lash is left or you start grabbing early. Its actually got a huge effect on the feeling of a shift overall.
- Torque Transfer -
Torque is transferring into the clutch pack. Pressure is building up and its starting to be able to transmit a torque. Torque transfers from an offgoing clutch to an oncoming clutch. This is done by increasing the pressure applied on the clutch pack. Basically we're letting the torque going through the transmission change from one clutch pack to another.
- Inertia / Slip Phase -
This is when the clutches actually slip, and this is what the driver perceives as the "shift" as the engine speed actually changes and the ratio of the transmission actually changes.
To control the speed of this, we have to deal now with all the internal torques involved in the transmission as the ratio changes and we deal with the input and output shaft torques.
- On / Maintenance -
The shift is done, and all we need to do is keep pressure on the pack so it stays engaged and can transmit the torque we require of it. Essentially the clutch is held at line pressure, and that line pressure is doing all the holding. Modern transmissions vary this line pressure with torque to help minimize transmission losses and improve efficiency.
As for what the adaptive algorithm does: It estimates how much fluid is need to precisely get the "fill" phase to cause the clutch pack to just start to grab, this lets it start the shift faster and smoother. This can vary as things wear, and varies wildly with trans-fluid temperature too. It learns this over the temp range and lifetime of the trans.
During torque transfer, the tune commands a set rate and time for the torque to transfer. The adaptive algorithm basically tries to figure out for EACH clutch, what the pressure to torque relationship is, so that it can hit the desired rates.
We as drivers shouldn't even notice the fill/torque transfer, we only perceive them typically when we click a paddle commanding a shift, as its the time it takes from us pressing a paddle and starting to feel the gear change. The faster the transmission does these, the more snappy those paddles feel, and the overall shift feel also is much better.
During the inertia phase, the ratio of the transmission is changing, and we're balancing two competing things: wanting to shift fast to minimize slip and go fast, and wanting the shift to be smooth without causing any upset torque on the output shaft that we feel as getting hit into our seats or the car stuttering, etc.
The transmission again is trying to adapt what pressures it needs to hit the requested times and torques, and doing so without tying up the transmission, flaring, etc.
The maintenance phase again, is the transmission learning the minimum amount of pressure needed to hit a set torque.
As for how Ford specifically achieves this, the answer is by the algorithms measuring what they can and assuming what that means. It can detect underfill, overfill based on how the input shaft speed responds as it fills a clutch. It estimates the torques on the clutches and tries to match the pressures so that its estimated torque is what it desires. It does this on every shift, sans conditions it considers it cant learn anything in.
When you clear the transmission adaptives, its essentially use base table data to control everything. The algorithms involved aren't necessarily perfect either. They are designed to be robust, and sometimes robust algorithms sacrifice perfection, and ultimately its not precisely measuring everything, its got estimations of whats actually occurring, and sometimes that limited data restricts how well it does.
Does driving soft vs driving hard give you different adaptive outcomes? Im not sure. The way the tables are setup for most adaptives is Trans Temp vs Torque vs Learned value. So it learns different values at different temps and torques, essentially requiring you to drive in all scenarios to learn. Some things it learns though, such as estimations of clutch friction and the like, arent as dependent. Typically if they feel they cant learn anything based on you driving with too little torque, or too much torque, wrong engine RPM range, temp range, etc.. they just dont do any adaption learning at that time. Id suspect youd want a varied range of driving to learn best.
dolsen
Louisville, KY, USA
I have to agree, everything I have read and heard about the adaptive learning of the Ford trans is that the "harder" (more spirited, not hard launching constantly) you drive it while it is learning, the better the trans responds and shifts.
Jessup, MD, USA
@Bugasu good to see you here! I remember you from the Focus ST forums.
