While trying to locate the source of this thumping in the front end at lower speeds (No luck), I decided to remove the front wheel for better access. Not sure if anyone has had a need to use the stock (So called) wheel wrench, but I would suggest you source a real wrench to carry with you instead of that piece of junk. It's a toy and I bent it easily and it didn't loosen the lug nuts. The longer I own this '20 ST, the more disappointed I am with Ford. Do yourself a favour and replace that wrench with a real one before you get stuck on the road.
