Forscan code
Huntsville, AL, USA
Hello all,
Has anyone made these changes with Forscan ??? :
Switch on the fog lights by turning the wheels
In the BDyCM module edit the line "Corner Light Mode for fog lights" and switch to Enabled
Set the number of flashes of the automatic flashing turn light instead of the 3 original flashes (in France)
In the AS BUILT Format SCCM locate the code 724.01.01 then replace the xxxx xXxx xx by:
0 = for 1 Flash
4 = for 2 Flashes
6 = for 3 Flashes
8 = for 4 Flashes
A = for 5 Flashes
C = for 6 Flashes
E = for 7 Flashes
Automatic door locking when driving from 20 km / h or 12mph (desactivated by default in France)
In the IPC module edit the line "Automatic door locking" and go to Enabled
automatic door locking function can be activated / deactivated from the ODB parameters (not existing by default in France)
In the IPC module edit the line "Self-locking configuration status" and switch to Enabled
Thanks,
Alex
I tried to add more blinks, but I could not find SCCM in for scan
Ashburn, VA
My understanding is that Secure idle is enabled on the STs by default. It's the feature where you lock the car w/ remote and then press the '2x' button 2 times (go figure) and it starts but is locked and won't go anywhere even if you got it and tried to drive away w/o pressing the Start button, which requires the key in proximity.
Ashburn, VA
Try using the As Built menus for changing the fog light behavior, it is menu selectable options instead of typing in hex codes.
Norvgen
Sun City West, AZ, USA
2020 EXPLORER ST
Thanks I’ll try that.
