Found this steering wheel cover.
Thread Starter #21
Pop the airbag out, unplug a few things then a Torx bolt holds it on. Take that out and it falls off. It literally takes less than 5 minutes even the first time.
Sumner County TN
2025 Ford Explorer ST 400a
Bag pops out with a console removal tool of sort? No screws or nothing?
Or not.
Derry, NH
What did you do with the suede cover?
I have one of these on my Ranger steering wheel. It looks like it fits nice on the ST. Does the steering wheel need to come off or does that just make it easier to stitch?
Thread Starter #27
Much easier with the wheel off. You have to take all the trim off anyway to do it right…might as well take out 1 more bolt and get the wheel off.
Derry, NH
Having trouble removing the airbag. I think I found the spring with a 3mm Allen wrench but I can’t unclip it. I just push on it in the Mustang and it pops right off. Am I missing something?
Thread Starter #29
Push in on one side while you pull out on the airbag a bit…once that side releases just hold it out while you push the spring on the other side and it’ll pop out completely.
2020 Whitehaven st, Washington DC 20007
Sorry to derail… @UNBROKEN did you change your black matte plastic dash for the gloss plastic from the 2021+? My understanding is that our 2020s all had the matte plastic and then they put gloss black in.
im only halfway through your build thread
Thread Starter #31
I did…then I replaced the carbon fiber inserts along the dash with some smooth ones I wrapped in piano black Vinyl to match the dash center. I only did that because the Aviator rear console has piano black trim and I wanted everything to tie together.
Got it. Well it looks badass. I wish I had that piano black to class up the joint. Thanks for the info
Derry, NH
Did you use the 3M tape with this cover?
Derry, NH
I was looking for an Alcantara console lid cover but I’m not finding anything. Have you seen any?
