Front axle leak cost?
GrocreyGetter
Terre Haute, IN
I noticed I have a front axle leak on this new to me 2020 ST. I fairly mechanically inclined have tools and could buy if need be. I see there is a TSB on the matter as well. I would like to have the updated version. Is this something I could do myself in a day or should I pay the dealership to do it? My dealership charges 135hr so it isn't that awful in labor cost.
What are part numbers if I attempt it myself?
Any special tools?
Time?
Should I let the dealer do it?
Is the updated version female to male? According to the YouTube video I watched that's what it looked to be.
Any help is greatly appreciated!
The OE front axles are about $150 each if I recall. They are a slightly different design so hopefully the boot won't fail prematurely like they did on the original MY2020-2021 axles. Drivers side takes 30 minutes. Passenger side, about an hour because you will spill front differential oil and it will need to be topped off--would be a good opportunity for a complete oil exchange if you haven't done that yet. You need to get the same part but updated part#--UNLESS you've had the FADA replaced before to an intermediate shaft--then the driver's side axle is completely different.
G
GrocreyGetter
Terre Haute, IN
I’m looking to replace the seal that looks like an oil leak but it’s the o ring inside the axle shaft. Apparently they updated it.
Geez. That is a big job. Unless you are highly skilled, you will want the dealer to do this and it won't be cheap. Definitely do not just get the O-ring replaced. Get the FADA TSB done which replaced the FADA with an intermediate shaft. And to be clear, it's not a front axle leak. It's an oil leak where the FADA inserts into the front differential.
Oh, and I should mention that this is a low pressure leak. I have managed to seal this up externally with a combo of sealant and sealer spray. YMMV but others have tried this and have been successful. 40k miles later and still leak free.
G
GrocreyGetter
Terre Haute, IN
What sealant and sealer spray did you use?
