Front sway bar endlinks
Sarasota
I've been told the bushings on mine are a little loose causing a noise I'm hearing. Has anyone replaced them with something like the Steeda ones? Is it even worth it for anything other than looks?
Stick with oem. There’s zero benefit to aftermarket. I’ve been through 2 sets of front aftermarket that flat ass broke and just swapped the 3rd set back to oem because they were starting to make noise.
S
Sarasota
Thanks for the input, I'll go that route.
After market sway bar?
Wonder if the extra stress of that bar is working those ends a bit harder?
