FS FS: Thermal 3” exhaust
Ldstang50
FL
Thermal 3” catback (downpipe) exhaust with black tips
Less than a tank of gas on it (300mi)
Wife hates the sound
$1200 + shipping (I’ll work with you on it)
L
Ldstang50
FL
Sold
mkwade
Illinois
View attachment 28301 View attachment 28302
If you don’t mind me asking, what did your wife hate about it? Was it just too loud or was there a drone or something at the speeds she drove?
My wife hated my thermal 2.5 after I put SPD down pipes on. Just too loud for around town driving. She didn’t mind it before the down pipes with just the thermal. Got to the point she hated trading cars when I worked on hers.
I put a couple Vibrant resonators and it brought it down to the pre down pipe loudness.
Morgan Hill California
2023 explorer st
Where did you put the vibrant resonators and which ones did you use?
These. You could also fit the larger canister type vibrant if you wanted it a little more quite than these. They took the higher annoying frequencies from the DPs away but kept the other goodness imo.
Vibrant Performance 1792 Bottle... https://www.amazon.com/dp/B000E3VHVO?ref=ppx_pop_mob_ap_share
One side about 5” from the down pipe. Other side slid into the front side of the Thermal dual resonator. The vibrant were a great slip fit. I put 4slits in the end of the vibrants with a cut-off wheel and clamped half on the slits and half off. Come spring I may weld them if I like them. Totally sturdy with no leaks now though so I may never get around to it.
The black pipe is a DP, I had them ceramic coated for heat rejection.
2023 explorer st
did it actually help low speed high rpm like 2500rpm light to light or just at idle?
Very little difference down low. When I would just normally accelerate like half pedal, it would start to get annoying above 2000-2500 with higher frequencies, like ricer-ish sound if that makes sense. Sounded like I was racing with normal driving. What I love about the Thermal is a lot of the sound is lower frequencies. It doesn’t sound like your typical V6. The DPs seemed to bring that annoying v6 sound into play. Still sounds awesome at WOT
