This topic has probably been discussed many times over but I would like to add a few details that I discovered during install.
1. Rear springs:
I only had to take 1 bolt off to remove and install rear springs - sway bar link bolt. I used the jack to compress rear spring and then inserted inside coil spring compressor, once I lowered the jack spring simply came out. To install the replacement, I compressed it first, popped it in, jacked it up and removed the compressor. You don't even have to take the wheels off if you have a lift.
Total time for both rear sides: 45 min.
2. Front springs:
I installed over 100 H&R springs on various vehicles and never seen them being installed upside down unless they call it for it (Supra). I went ahead and emailed their service dept and got a confirmation that lettering has to be upright, top of the spring has to sit flush and not the bottom. I confirmed it with the stock spring and it also tilts to 1 side.
Total time for both front sides: 2 hrs and 2 beers
Car dropped about 1" in the front and 1.25" in the back right after install. After 50mi drive they settled in around 1.25F/1.6R. Will update after 1000mi.
Ride is significantly better, more planted to the road. Not harsher at all comparing to stock. It absorbs small road imperfection way more predictably.
- internal spring compressor
- spring pops right out
- stock vs hr front springs comparison
- stock ride height
- hr after 50 miles
1. Rear springs:
2. Front springs:
- stock ride height
- hr after 50 miles
- 4
- Show All
