Hate my 3" thermal exhaust
BigAnt75
Haslet, TX, USA
Just a reminder we bought a V6 Explorer not a V8 Mustang lol we all need to relax …I have the Thermal 3inch and it will never compare to my Borla on my old Mustang GT. It’s my family hauler and I like a little sound now and then …if you want to really compare get a V8 not a V6 just my opinion
The midwest
Oh, a follow up to the whole the "the stock flows fine" discussion, and that it's already high flowing, mandrel bent, etc.
It has a flapper valve in it. I was getting my old OEM ready today to try to sell it (anyone want to buy an OEM exhaust in great condition?) when I noticed a little knob looking thing. I played with it to see what it is/does.
It's literally a blocker valve thing on a spring. Like a throttle body plate. Presumably when there's enough exhaust flow, it forces the valve open. It's positioned right after the mid pipes, before the central muffler/resonator thing.
The valve closed, with a flashlight on it (it has a little hole in it):
The valve open half-way, I'm twisting it against the spring tension:
The valve just about all the way open:
There's a little ball on the opposite of this plate, it looks like a flapper valve from a toilet. This device is called an Adaptive Valve, and its job is to attenuate low frequency sound in the exhaust. It works to keep the exhaust quiet. These valves do increase backpressure, though they maker claims only a "moderate" increase.
It's worth mentioning that aftermarket exhausts, such as ones from Thermal R&D, do not have these devices in them.
That’s a very early system from the initial production run. They are all dual inlet/outlet (at the resonator, obviously) from somewhere after the beginning of ‘20.
The current quickest stock turbo ST 0-60 uses a stock cat-back. The oem exhaust isn’t a restriction for 95% of ST’s. They also stopped using that valve in 2020.
Ah, well now that is interesting. Thanks for letting me know :)
Morgan Hill California
2023 explorer st
That is the main reason I changed mine also. I realize there is a compromise with the sound. I love the sound at idle and cruising, but when you want to go fast, it is really loud. I paid $1848 shipped from Lethal, so I guess I will try it for a while. Maybe I can find a quieter mid muffler.
did you find something better or a fix for the volume? My 3 inch is way too loud as well.
Add a couple of Vibrant Ultra Quiet resonators at the end of the downpipe. It will quiet things down a bit.
2023 explorer st
anyone actually done that or are you assuming?
i rode in a 2020 with 3inch and it was much more bearable idk but mine is LOUD in first thru 4 stop n go! sounds great after that. My first thought was adding the vibrant ultra quiets or selling the system and trying the 2.5 and then back to stock with tips maybe idk but im bummed
2023 explorer st
I don’t assume. I build exhausts for fun.
would you have a recommendation for a quieter muffler to replace the rear mufflers on the thermal? Just asking thanks for your replies.
Phoenix, AZ USA
'23 Expl. ST and '24 'Stang GT Prem., Rapid Red
Wow...I just read this entire thread...not EVERY word during the bickering, but most...and all of it makes me VERY happy I have a 2-1/2" Thermal exhaust system in my otherwise-stock (but for tires and wheels) '23 ST, and I LOVE the way it sounds.. Its a bit louder than stock, but it's a very attractive 'loud', and it DOES NOT DRONE.
