Help identify this sound please. 2020 Ford Explorer ST
JMCD915
California
Phone was placed under the passenger front end.
was driving on the freeway home when suddenly car got louder and shook a little. it makes a grinding noise when accelerating.
First 2 revs are in normal mode ( listen to the end of the rev) , then i switch to sport and you can instantly hear a grinding sound.
I have gotten 3 opinions so far from mechanics who do free diagnostics.
first one said torque converter
2nd one said trans
3rd said one of the turbos
Greatly appreciate any help ( VOLUME WARNING)
That sound is perfectly normal. Big thread going around about it, something about Sport mode engaging something.
J
JMCD915
California
Appreciate the reply, anychance you have a link to the thread?
BMW X5, Black 2020 ST
[/MEDIA]
3rd one was trying for the biggest rip off. lol
Sound at 0:26 almost sounds like exhaust shields rattling. Is that the sound you are concerned about? Everything else sounds normal.
The rattle doesn't seem to increase with the RPM's so it's definately not a turbo.
Unfortunately I don’t have it on hand, but a quick search might result in some finds.
J
JMCD915
California
Appreciate the reply I will check the shields
FORZDA3
Gloucester, VA, USA
There is DEFINITELY a sound change from the transmission when you select Sport mode. Yours sounds normal to me. I haven't placed my phone, or my chassis ears microphones under the car because its NORMAL sounds…
If you must DO something about it, just check the transmission fluid level correctly and adjust as necessary. The car is not “broken”.
J
JMCD915
California
just wanted to update here incase anyone comes looking for the same thing. i solved my issue. the flex mid pipes were broken and causing a rattle / vibration. the pipes from the muffler back were craked at the welds causing more noise. A muffler shop down the street fixed the cracked weld for 45$. New OEM flex pipes were 200$ each on the fords parts stores online so i ordered a universal section of flex pipe and cut out the bad ones and use couplers to install the new section. about 60$ on amazon.
