It looks like for de-contented the front climate control at some point removing the little temp screen above the temperature buttons. Does anyone know if the older controller can be swapped in and the display work without further modification(edit: spoiler, it can)?
Update Guide:
Heated seats and Steering wheel. Part # LB5T-18C612-DG
Heated/cooled seats, heated steering wheel. Part# LB5Z-19980-D
guide linked before for removal and install of the controller, I believe you will need t-20 torx bit for the screws holding the controller to the face plate. The guide also calls for a 7mm socket for the screw attachment for the lower section of faceplate.
You will need a forscan setup, you will need to save the HVAC controller data from you factory installed controller, and write that config to the new controller once installed. Some things seem to work without a written config, but there are a lot of config flags to write. Brand new controllers have all NULL config data.
@randyknight made a video of the install -
Update Guide:
- Show All
