How-to: Front climate control swap(add 20-21 temp display to 22+)
locoliberty
locoliberty
michigan
2022 ST
Thread Starter #21
Anyone have access and post the instructions to remove and replace the hvac controller? thats the real next hurdle is how to physically install this one.
Sacramento, CA
2022 ST
in to see if this works...
dolsen
Louisville, KY, USA
I think your best bet is going to be to go into the service manuals available to rent on motorcraftservice.com You can rent them for $23 for 72 hours. I've used it a few times and it helps a lot. It's not as detailed as it could be, but it's good
Perhaps I've missed this, did the change move the readout to the viewscreen or is there simply no temp display?
dolsen
Louisville, KY, USA
My 2020 has the temp readout on the HVAC module face, but it appears it was removed for either 21 or 22. Same thing happened with the F-150's, and possibly other models as well. The temp display is now on the sync screen at the top
Got it, thank you.
locoliberty
locoliberty
michigan
2022 ST
Thread Starter #27
Can confirm, you will need to write the hvac asbuilt in forscan. Ill grab some picture but the tear down is straight forward but a the clips make for a little anxiety 20221213_180034.jpg
Columbus, MT, USA
Nice work! What did the controller end up running $300 and change? and was the forscan programming pretty straightforward backup and re-write or was it pretty involved?
locoliberty
locoliberty
michigan
2022 ST
Thread Starter #29
about 110 when you buy online from a dealer. part LB5Z-19980-D
Programming was just saving the HVAC asbuilt, and then writing it out. Some of the module works without programming, but none of the seat control buttons did.
dolsen
Louisville, KY, USA
#30
I did mine in my F-150 over the weekend and it was the same deal, drop in factory as-builts and carry on. Glad to hear it went smooth
PDF file of the tear down.
Sacramento, CA
2022 ST
#33
its crazy how trivial this is but how much I want it...hmm @locoliberty where did you buy from?
I Bleed Ford Blue
23 Rapid Red Explorer ST
#34
My 21 still has it with a build date of 3-27-21
locoliberty
locoliberty
michigan
2022 ST
Thread Starter #35
I bought it from an online ford parts dealer, tasca/varsity ford any of those types will work
locoliberty
locoliberty
michigan
2022 ST
Thread Starter #36
dolsen
Louisville, KY, USA
#37
It may be trivial, but I feel exactly the same as you. I spend more than triple what locoliberty did for the HVAC module with temp readouts for my truck. The little details matter
Columbus, MT, USA
I agree 100% on this one. Not needed AT ALL. However, I find myself wanting just the same. I ended up paying around $120 for my rear HVAC control because I wanted it right now from wherever I could find at the time. Didn't matter it was free if I wait :) This just seems so obvious that it should be there that the mod has to be done!!
randyknight
Chelsea, AL
Just purchased one and now I need to buy a forescan license to write the as built onto it. 105 bucks from livittown ford not too shabby at all…
