IC Cold Side Pipe
Suprawill1
Maryland
Hi All,
Is it complicated installing this pipe after an IC upgrade or is it more practical to do it while installing the IC?
Thanks.
yettihead
Lisbon, WI
2021 Ford Explorer ST - Infinite Blue Metallic
Hi All,
Thanks.
I changed mine recently and it took 30 minutes or so. It would definitely be easier while upgrading the IC, but you can still easily do it afterwards.
Suprawill1
Suprawill1
Maryland
Ok, thanks for the confirmation yettihead!
It’s a simple swap either way. How long it takes will depend on what version you’re installing and what year your car is. If you have an early model, then you’ll have to deal with the factory bypass valve and wiring in the resistor for that bit if you have a newer car you’ll only have to deal with tapping the vacuum line for whatever blow off valve you got. If all you got was the plain charge pipe then that’s just a five minute swap.
Suprawill1
Suprawill1
Maryland
Yeah, I'm going to go with the S&B pipe on the 2020. Thanks for the hit!
