Installed a really slick LED strip - hope you enjoy!
Toadster
Toadster
Folsom, CA
Thread Starter #41
You may want to try the 15A in #26 - you need key-on power, I’d think the transmission control module would only be powered when the ignition is on
Daamus
dallas, tx
2021 XLT
#42
I actually got it to work last night by using another 10a fuse in the #134 spot for 'Family Entertainment System'. Only thing is now it doesn't come on with remote start, only when started from inside the vehicle, I assume this is because the radio needs to be on now for it to work.
I'm so confused as to why I dont have a fuse in #21 but my headlamps are functioning just fine?
Toadster
Toadster
Folsom, CA
Thread Starter #43
glad it's working, #21 is for adaptive headlamps so maybe not an option on your car - assume when you start the car (when in the vehicle) is when they work?
would have to understand the vehicle wiring schematics a bit more, maybe tie into a marker/parking light fuse? those I believe come on during remote start
N. Florida
22 is the Electric Power Steering. That should be valid.
N. Florida
The DRL and parking lamps are in the panel under the dash. Unless the lead for the parking lamps can be positively identified, getting to that panel may be the only way. Does anyone know a good path through the firewall?
Daamus
dallas, tx
2021 XLT
#46
went to show my buddy the light installed and found that part of it is not functioning :(
only lighting up over the driver side headlight now. Has to be a bad light right? Did the TX heat kill it?
Toadster
Toadster
Folsom, CA
Thread Starter #47
very odd - send feedback to the seller, they may replace it - we've had 108-109F days here in NorCal - our strip is working fine
N. Florida
Does the chase not light either, or does it settle with one side out?
ARKY
Mountain Home Arkansas
Not yet - I installed it and my wife works nights so I have to wait till her week is done
I really appreciate all the information you provided on this hood LED strip. I'm going to get one myself now and install it, all of the information you provided will make it so much easier. I noticed the blue strut brace, can you tell a difference with a new one instead of the factory installed? If so, if you don't mind me asking which one did you purchase?
Copper2020
Nurse
Austin TX
NGL that looks dope af and really looks like it belongs. Not garish or gaudy.
Toadster
Toadster
Folsom, CA
Thread Starter #51
it's the steeda strut tower brace, you call them and they'll powder coat it Steeda Blue for an extra $25 - I love it! can't really tell much of a difference, the chassis already feels pretty tight from factory - I'm sure it helps if you're pretty radical with your driving though :)
Long Island, NY
As per the SilverHolder website,
Can these be cut down?
You can reduce the length, but you need to use waterproof glue to cover the cut port to make the light bar waterproof.
This makes these even more attractive.
Buy them from Amazon.com: SilverHolder Car Hood Light Strip White 70 Inches Exterior Flexible Daytime LED Running Light for Cars, SUVs, Trucks : Automotive and return them if they get screwed up. Just say they didn't work. Free return shipping.
sburg1616
Mandeville, LA
2018 Ford Raptor
#53
@Toadster I recently bought the same light strip, I love it and get compliments all the time. Thank you for the write up and pictures it made my decision easy. Got a question you might be able to help out with. The strip I purchased has a blinker function, but I was unable or just too lazy to figure out how to wire the blinkers up. Any idea where I can tap into the blinker on the main wiring harness on the headlights?
https://www.amazon.com/gp/product/B0BYP3QPZX/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
Ljn21
Fort Mill, SC, USA
#54
Has anyone got this to work and was able to leave the OEM seal in place?
Toadster
Toadster
Folsom, CA
Thread Starter #55
I’m sure it can stay in place - just have to place the strip in front of the seal - honestly I was just doing a quick setup and ripped the seal out
Toadster
Toadster
Folsom, CA
Thread Starter #56
Unsure of the blinker tie in - would want to tie into the turn signal flashers though
Fade2black
South Jersey
Hi,
just installed this and figured out if you undo the hood lock bracket on the hood and place a washer between the hood and the bracket I was able to latch the hood without removing the weatherstripping.
#58
Hi,
Is there any noticeable abnormal spacing between body panels like a Tesla though?
Fade2black
South Jersey
It looks e the same to me, didn’t notice any difference
