Hi everyone,
I have been following this forum for over a year. I had a 2016 Ford Explorer Sport and didn't muster the courage to try this on forscan. I recently purchased a brand new 2023 Explorer ST, and decided to give this a shot. I literally went to the store and bought a $200 Windows Laptop just to do this because I've been dying to.
I did not go into the nitty-gritty lines and changing the numbers. I was able to (1) turn on the turn signals as DRLs, (2) remove the glowing white LEDs atop the lights, and (3) activate them for daytime AND night time use. I have NOT, however, been able to figure out how to use the turn signals while they are on as DRLs.
I changed the following settings in Module Config (NOT AS-BUILT FORMAT)
(1) Police Dark Car (enabled)
(2) Police Dark Car - DRL (enabled)
(3) Right AND Left Front Turning Lamp Usage (Turn Only, Turn, DRL and Position)
(4) Right AND Left Front Position Lamp Usage (Position and Park)
(5) Right AND Left Front DRL Lamp Usage (Fixed DRL and Position)
(6) Parking Lamps as DRLs (Enabled)
(7) Right AND Left Low Beam Usage (Low Beam Only)
(8) There was also some setting about using parking lamps as DRLs, I enabled that.
I have NOT been able to figure out how to activate this as a turn signal without removing the "POSITION" setting on the Turning Lamp Usage setting. When I removed this, the amber lights did not stay on constantly. This is also with the DRL setting ON in the vehicle settings. Changing this setting did not modify any of my lights. On a weirder note, I was able to activate the WHITE GLOWING LEDs atop the main vehicle lights as turn signals. This looked stupid, however.
If anyone knows how to use the Parking Lamps as turn signals while keeping them on all the time, please let me know. This was my first time messing with ForScan, so I do not feel comfortable modifying the numbers without knowing where to go. if someone can help, it would be appreciated!
