Ok, so I decided to give something else a try. I ordered some self adhesive velvet sheets and 1mm thick felt. If this all works out and anyone wants to do the same, I can link to exactly what I bought off Amazon for this.
After taking the door apart again I did notice that the foam washers I made really did get squashed down, so I created some new ones from the 1mm thick felt that I got, I have a feeling these will hold up much better and not crush like the foam. At the same time I decided to replace the paper ones as well with the felt. Getting those out was easy, but putting the felt back in was more of a challenge since they are much thicker. With a little patience and creativity those are all replaced.
Now here is where the velvet comes in. I am cutting strips to line all of the surfaces that come into contact with the door card and could potentially rub along the vinyl.
This is pretty much where I am trying to avoid any contact on the door card
Lastly, since I had it apart again, I decided to put some of the velvet along the tabs that lock the top piece onto the door itself. There are 9 of these areas that I did. I had only started when I took the photo.
Once this is all back together and I have some time with it I'll update this to let everyone know if it has really solved anything. Now it could take a little time to report back any success/failure since I am still having issues after the engine replacement and it's going back to the dealer Monday morning for that again.
- 1
- Show All
