Is alignment needed???
ARC
Oak Lawn, IL, USA
2022 ST Black
Hello,
Looking for advice, opinions on any who may have lowered their Explorers.
Just ordered the Steeda spring kit for my 2022 ST.
Do I really need to have the truck alignment done with only 2k miles on it after the springs are installed?
Thanks
Yup.
Airizona
like the others said... it's part of what needs to be done
Charles Town, WV, USA
your effectively changing the suspension geometry by lowering it so yes it will throw your alignment out of wack. Dont hesitate either, it will cut tires quick, You'll want to do it right after.
Fort Worth, TX, USA
Has anyone used any camber bolts for the rear or front? Installed h&r some time ago and then when I took it to get aligned they said it was just outside of factory specs but they couldn't get it to factory specs without camber bolts. TYIA
Find a shop that knows what they’re doing. It will align perfectly without any extra parts.
Planet Earth
Indeed, I also have the Steeda springs -- before measurements showed quite a bit changed, but they had no problems getting it back in alignment.
