Just hit 50k
ARC
Oak Lawn, IL, USA
2022 ST Black
Hello everyone.
Just hit 50k with my 2022.
Anyone have any input as to what maintenance should be looking at?
As always thanks for the input.
2022 Just hit 47K on my way to work this morning.
This weekend, getting the transmission serviced. $415 at the Ford Dealer.
36,250 Miles : Changed rear diff fluid
37,486 Miles : Change Spark Plugs.
50-60k: I'd do spark plugs, front differential oil, transfer case oil, rear differential oil, transmission drain and fill, brake bleed if not done in a while.
Hello everyone.
Transmission fluid should be top of your list. Then just spark plugs if needed and if you want to go all the way transfer case fluid, and front and rear diff fluids although I don’t think they are that important.
ARC
ARC
Oak Lawn, IL, USA
2022 ST Black
Yeah, so Trans filter and fluid seem to be the common topic, that is what I was thinking.
