Just installed a Whipple intercooler.
Calgary, AB, Canada
I think Mishi making a option will be great. They also do CARB EO certs, so it will be one that you can run anywhere.
H
Columbia, TN, USA
Thread Starter #22
Is this consistent every day so far?
Sorry for the dealyed response I have been sick. Yes I am very pleased with the upgrade. It accelerates a lot better
H
Columbia, TN, USA
Thread Starter #23
^This, also any tips on install?
Sorry for not responding but have been ill but now better. The install is pretty in depth but went smoothly. I am glad I had help because it would been difficult trying to get the bumper off by myself. The install took about 3-4 hrs. I took my time.
Kingcor
Sicklerville, NJ, USA
If I’m not planning on tuning is this mod worth it? Would the money be better spent elsewhere for performance increase if not tuning?
Fort Worth, TX, USA
This is absolutely worth it even if you're not planning on tuning. I installed mine back in June before I was tuned and the difference in acceleration is immediately noticeable. It feels like the engine is just having a much easier time.
H
Columbia, TN, USA
Thread Starter #26
I think it is worth installing. It makes the ST accelerate better and run smoother.
Definitely a worthwhile mod for increased performance and enhanced reliability. If you are just puttering around town easy on the gas all the time then no, but if you want to drive the ST the way she should be driven then yes. Remember the Ideal Gas Law from physics? Hot inlet temps cause your ECU to pull timing so you don’t have pre-ignition ( aka detonation). Pulled timing = less performance.
Kingcor
Definitely a worthwhile mod for increase performance and enhanced reliability. If you are just puttering around town easy on the gas all the time then no, but if you want to drive the ST the way she should be driven then yes. Remember the Ideal Gas Law from physics? Hot inlet temps cause your ECU to pull timing so you don’t have pre-ignition ( aka detonation). Pulled timing = less performance.
Thanks I appreciate the insight. Now I’m just debating if I get the whipple now or wait for the Mishimoto to one to be released. I’m not sure they will be all that different right? Any reason worth waiting?
I see no reason to pass on the Whipple. They are well respected in the industry and I don't believe anyone that has installed one, including me, has anything bad to say.
Jshaffer3819
Kaiserslautern, Germany
#31
I have a tune on mine now from ZFG Racing. Will I have to get it re-tuned if I add the Whipple?
South Palm Beach, FL, USA
#32
Just ordered one! Hope it helps in the South Florida heat! Thanks all.
Tommy
Airizona
#33
I wouldn't say that you have to, however to take full advantage of the new IC it would be good to have Adam do an update.
Jshaffer3819
#34
Ok cool. Thanks for the response. I may take my chances and do it myself.
Airizona
#35
The install isn't bad, just take your time. To make sure I put all the bolts back where they go I bought some cheap zip lock baggies and labeled them for each area I took the bolts out from.
Troy, MI, USA
#36
Who has the best price on the Whipple? Looking to pick it up, but the cheapass in me is waiting for a sale.
Charlotte, NC, USA
#37
Hey Big J there are a couple of options other than Whipple. One has terrible ratings in customer service, and the other is almost ready for release. I've been watching as well but decided to spend the money and go with Whipple. I've heard no complaints from those that did. Just do a search for explorer st intercooler and read up.
On that note. Once I have everything apart, is there any upside to removing or partially removing the block off plate on the backside of the grill. Appears it would increase air flow across the IC and radiator.
I actually strapped a camera on my grill and recorded the shutter slats while driving. They didn’t close at all up to 85mph. I think they only close in cold weather to help warm the car up. The 85mph was only for a second, so not sure if they close at hwy speeds and long durations. Even so I wish I would have removed mine when doing the IC install.
Regarding Whipple vs others, just go Whipple. Mishimoto, or however it’s spelled, has had this teaser out for months and no true updates on progress. Zero drawbacks on Whipple’s design or performance.
Charlotte, NC, USA
#39
Thank you Twin 001. I've read some stuff on the shutter slats. Think someone mentioned it threw a code fault when he removed them. Someone else just removed the slats, kept everything else in place and no code. I'm specifically referring to the flat plastic attached to the backside of the grill. If you look at a PIU version it is very visible not as noticeable on the ST but is still there
RobHalo
NJ
#40
I saw Mishimoto quote Spring 2022 as an ETA for their cooler, and I'm sure that doesn't account for possible manufacturing/shipping delays. I can't imagine any difference substantial enough to be worth waiting for.
