JXB bushing insert
Jessup, MD, USA
#41
You have a pinion bearing that is going out in your differential, same happened to mine after installing the inserts. I replaced the rear diff out with a used 30k mile unit and fixed it. Diff was inexpensive but took about 4-5 hours to replace it.
Is that a common failure on these? Any early symptoms to be aware of?
Bigal2001
DFW
I have seen a couple posts about people having issues with the rear differential. I'm sure mine was wearing prematurely but only noticed it because of the bushing inserts. The symptom was a grinding sound on deceleration, the fluid that I drained from the bad diff had a lot of metal flake.
#43
I received word today that my 2020 ST with 54K miles has to have the RDU (Rear Differential Unit?) replaced again after a few thousand miles. The PTU was replaced twice also. Today my service advisor said they think the differential installed a few months ago "had the wrong gear ratio set up." WTF! I still think something with the TSB for the FADA deletion messed everything up.
Go look at the paper tag on the diff. It’ll clearly say the gear ratio. You should see 3.58.
My 2020 has 96k miles. It would not be surprising if pinion or carrier bearings are showing signs of wear. Still, there is no oil leaking out of pinion or axles which I would expect there would be if bearings were seriously degraded. Also, the noise when off throttle was only noticeable with the JXB inserts...and I believe only those with the double inserts have reported this. I suspect this is because the passenger side insert sits deep into the mount and there is more transmitted NVH of the insert face to the mount collar. Don't plan on jumping the gun and replacing the rear diff but if I do, it doesn't seem like a new one is all that expensive.
#46
It's been in the shop since last week. Luckily it's still under powertrain warranty until Dec. 4. I have extended warranty for 2 more years and 30K miles.
Canada
#47
Just installed mine this weekend. I noticed more planted shifts. I also noticed more noise from the diff, especially when there is slack in the power (letting off the accelerator while moving). Sounds like a dull grinding or a very deep hum. Anyone else notice increased NVH? Should I be concerned?
I’m getting the exact same symptom when letting off the gas or slack in power.
unfortunately I’m also getting a distinct vibration around 30mph and again around 60mph…taking it in tomorrow to investigate.
College Park, Maryland
Keep us posted. I too have a vibration around 60 then again at 76 mph.
Did you replace with P/N S606B?
JXB inserts are great. That said...
Just dropped my ST off at dealer to have the pinion bearing noise diagnosed and (hopefully) replaced under my ESP. The associate already started dropping the enviable bulls**t of "aftermarket bushings and bolts change pinion angle"...
#52
Aftermarket bushings and bolts don't change pinion angle, they keep it from being bad and force it to stay at the correct angle. Love how uneducated some service advisors can be.
Exactly. My terrible choice to install aftermarket simply identified (another) longevity issue with Ford parts. Had I not installed aftermarket parts, how would I have found out that the pinion bearing is going bad a 60k miles...riddle me that???
BeyondEOD
Active Duty U.S. Air Force
Missouri
I’ve got some noise under 35mph now that I have installed the Steeda Pinion Bushings, JXB insert, and the AWR brace. Only on light accel. Not sure it’s worth explaining myself to the service department with all the parts on there is it?
I'm still waiting to hear back from the dealer. I'll post their response. I'm sure it will help you with your decision.
And, the funny thing is, all of the parts you installed are to compensate for Ford's poor design! They should be thanking us "aftermarket" folks for extending the longevity of Ford's product.
#57
Not saying it applies to you guys, but could just be those parts causing more NVH. Could possibly be normal, but I don’t know how bad it is occurring.
BeyondEOD
Missouri
yes I was definitely considering that since mine only makes some additional noise a low speed accel. Nothing at high speeds or decel.
Dealer said tires are cupped and they cannot/will not diagnose any other issues until tires are replaced
Jessup, MD, USA
#60
That sounds like the dealer really doesn't want to replace it. Did you get it fixed?
Did your pinion bearing show any symptoms when you had the OEM parts?
