Leaking oil?
I don't have any error codes yet. I'm sure it will eventually happen as it is slowly leaking. Do you think the dealer will still address it, or make me wait until the code appears?
Dealers tend not to do anything until a code appears. With just a leak, the dealer will be replacing only the O-ring with the revised part. That said, I externally sealed the FADA leak with Permatex red sealant and also Permatex spray sealant, after cleaning with brake cleaner (as mentioned earlier in the thread). It's been a year and the "fix" has held, so it must be a low pressure leak. It's quite possible the FADA fails because it drains all the oil from the front differential.
Black 2020 ST
#82
With the help of @Cdubya I did a thorough external sealing (over 24 hour process) and it is fixed.
Jessup, MD, USA
#83
I take it that they only replaced the O-Ring based on my invoice.
Yes, but they also replaced the driver's side half shaft for some reason.... was the boot leaking grease?
Jessup, MD, USA
#85
Yes, it was. The transmission was leaking too, but they couldn't replicate it.
Do you have any pics of your permatex fix?
wycsailor
Minneapolis, MN, USA
#86
Another winner here, thankfully fully covered by the powertrain warranty. I'd like to also say how much I appreciate this forum. It helped me be proactive and check it closely since the dealer hasn't said anything during Quick lane oil changes. Perhaps they don't remove the deflector since they pull from the top. IMG_4228.jpg
kimmonia
Midwest
#87
Another leak getting the FADA TSB done as soon as dealer gets the parts in! 2021 at 48k for another data point.
Philadelphia
Same for me. 2021 at 55K, warranty replacement but work pending until mid September.
Hopefully they do the full FADA TSB and not just O-ring replacement.
Philadelphia
Hope so too. I just got a Shift System Fault today so it looks like I need to tow it in.
Frederick md
I have a similar issue. I’m taking mine in on 12/3/24. 58600 miles, poor design and QC on Ford’s end. Hopefully it’s covered under drivetrain warranty.
Anybody know if it will be covered?
My 2021 looks to be waving a similar issue
Yes, it should be covered under powertrain. mention the FADA TSB. It would be a wasted opportunity to just get the O-ring replaced.
Frederick md
Thanks
Elk Grove, CA, USA
#96
Dealer completed work under drivetrain warranty. No deductible. Completed. Just make sure they use correct jack points. Twice dealer failed to use proper jack points and crushed pinch welds
JPM
Chicago
I'm grateful that I ran across this thread. Just went to the dealer today and they told me the front axle disconnect O ring is leaking and needs to be replaced. The rub is that my odometer just kissed 60,073 so power train is out of force. Of course the tech didn't even mention that the power train would have covered the repair and the quote to replace the O ring was ridiculous. Is there any chance Ford would cave and cover the repair? Has anyone else had this happen outside of warranty and if so what was the quote to complete the repair?
By all means, contact Ford customer service to see if they will pay for it out of good will. This is a known problem and Ford should have recalled all Explorers which used this substandard O-ring--basically all 2020 and most 2021. If you get no love, do what I did and seal that puppy up externally with gasket sealer and spray. Mine has held up 2 year and 40k miles...
Jose131
Fredericksburg, VA
FORD EXPLORER 2020 ST
#99
Does mine look like it needs to replaced?
2020 ST 43K miles
how much is expected to pay out of warranty because mine is tuned and I don’t think they will warranty it like that.
2020 ST 43K miles
Yes, you have the FADA leak. They won't care about the tune... it is a known issue. Definitely get it fixed before powertrain warranty ends. Try to get them to do the FADA TSB and not just replace the faulty O-ring.
