I recently found that I have a very small and slow leak in my transmission. I noticed some red fluid on the heat shield every time I drove. It would especially pool towards the rear of the transmission, sometimes even dripping slightly off of the back portion of the pan.
I removed the heat shield and cleaned the area thoroughly and drove some more, I believe it is actually coming from the front right section of the transmission. I found fluid above where the plastic pan meets the transmission, so I don't think it's the pan gasket.
Any idea what it could be? I know there's a vent in that area. My next possible suspect is the input shaft seal is leaking on that side.
Has anyone ever experienced this leak?
