Lug Nuts
I’m looking for a set of lug locks and I’m getting two sizes. It’s seems the M14x1.5 are coming up more frequently but I’m also getting M12x1.5. My ST has the standard 20” wheels. What is the correct size?
M14x1.5
Thank you!
I believe both the 20" and 21" come with the large (base diameter) bulge lug nuts. The small bulge will fit the stud but doesn't give you as much surface contact area on the wheel. In short, big is good if there is sufficient room. That said, if you're looking at new wheels you'll want to see which is recommended. Many aftermarket wheels do not have sufficient room for the large bulge lug nut.
