Multiple error codes...
s0nguy
Nashville, TN
2021 Explorer St
Hello all,
Firs post here. We own a 2021 Explorer ST a check engine light recently came on. The car is difficult to start after fueling. I refuled it while it was running and I think I broke the purge valve.
I am getting the following error codes:
P0496
P2196
The dealr wants at least $1000.00 to fix it. Does that sound normal?
I can see the part that needs to be replaced and it doesn't look too hard to do but it does look hard to get to. I am in the Nashville area if anyone has a mechanic they'd like to recommend.
Thanks in advance!
S
s0nguy
Nashville, TN
2021 Explorer St
Yes I have seen that thread. I am not the best when it comes to working on cars... houses, yes... cars no. I will dig a little deeper into it. I guess Ill have to remove bolts and things like that. Is is bad to continue to drive it?
After looking again, there a picture with the 4 bolts to remove so I think I will attempt it. I ordered this:
https://parts.ford.com/shop/en/us/fuel-tube-support-bracket-fuel-line-bracket-p-gl3z9b325b?pdp=y
thanks
It’s probably okay to drive but I wouldn’t wait for it too long.
